It is currently Wed Jun 25, 2025 4:24 am
 Post subject: exhaust manifold studs
PostPosted: Wed Mar 29, 2006 11:53 pm
on the gti manifold the studs at the bottom have broken off. I can replace them with some grade 8 studs. Should I use stainless studs? I was thinking of using just grade 8 studs and making up some brass hex nuts, but twice as long then usual nuts. Or should I just stick with the grade 8 studs and steel nuts.....?
PostPosted: Thu Mar 30, 2006 5:55 am
Stainless is weaker. Trust me I've seen enough busted ones fixing outboard motors... :x
I'd stick with grade 8. :wink:
PostPosted: Thu Mar 30, 2006 10:40 am
Stainless also expands more with heat
- not a good result on exhaust manifolds
Go the brass/high tensile option!
