It is currently Sun Jun 22, 2025 4:49 pm
PostPosted: Tue Jan 24, 2006 2:59 pm
Minstar... Dont stress to much... 18months is not tooo bad...
I have just hit 13months...
Baracade
PostPosted: Tue Jan 24, 2006 3:55 pm
Yeah Dean you're right. But you know how it is, some says "I welded up my subframe last weekend", and I'm thinking to myself "crap it took me 6 weekends to design and weld up mine. Still that's all done.
Still I dropped it off at the Auto Elecs and I am bit worried they don't have a clue what they're doing which means it might end up costing me an arm and a leg... :(
PostPosted: Tue Jan 24, 2006 7:36 pm
Hey Matt,
Well the demon is on the streets.
Congrats big boy - you deserve it.
Its coming up to 12 months for me on the 25th April - thats the date I did my first cut.
And I still need to finish the rear boot, and the rest of the fab, and then paint the car.
I think yours is about par for the course. :wink:
Anyway - enjoy it.
Andy
PostPosted: Tue Jan 24, 2006 8:42 pm
Yeah I'll shut up. Probably getting a little stressed because its getting close to completion. :oops:
PostPosted: Tue Jan 24, 2006 9:20 pm
:oops: 3 1/2 years, off & on :roll:
PostPosted: Tue Jan 24, 2006 9:23 pm
Yeah that pretty much puts it in perspective. How much do you reckon would be a reasonable amount to pay to have the headlights, indicators, fuel pump and wipers hooked up by and auto electrician? So they work off the starlet instruments...
PostPosted: Wed Jan 25, 2006 6:18 am
matt i think i got quoted $250-$300 for that exact job when i was building mine, i ended up just doing it my self except for the wiring in of the fuel pump which i got done as it needs to be done through the ecu.
1974 Moke - 998cc
PostPosted: Wed Jan 25, 2006 6:30 pm
Ah Brad I am glad you mentioned that I was wondering that because I heard that some ecu's control the power to the pump so that is lowers the pump pressure at idle and bumps it up when you floor it. Well they tell me it should be ready next week as they are short staffed so I guess a bit patience is required...
PostPosted: Wed Jan 25, 2006 8:10 pm
Sound good Minstar :lol:
The ECU doesn't control the fuel pressure the regulator on the fuel rail does according to the manifold pressure .
4efte powered Clubman
supercharged 998 race car
PostPosted: Thu Jan 26, 2006 12:00 am
92, some cars including Toyotas run a variable speed fuel pump circuit. This delivers variable voltage to the fuel pump thus changing the output (PSI) the pump delivers, the ECU monitors things like throttle positon to determine wether more fuel is needed and increases or decreases voltage accordingly. This was mainly to minimise noise from the fuel pump on large fuel pumps and to make them last longer. This is also irrespective of the fuel pressure regulator.
Matt
PostPosted: Sun Jan 29, 2006 8:33 am
4efte's use as simple on off relay controlled by the ecu (and start position on the ignition switch) so the pump runs at a constant speed
PostPosted: Sun Jan 29, 2006 11:10 am
Thanks 92, that was my question really, does the 4efte use a simple relay or is it something more complex. Thanks for the info, I couldn't find a definitive answer on the internet.
Matt
