Primary gears https://ausmini.com/forums/viewtopic.php?f=2&t=99988 |
Author: | Bubbacluby [ Mon May 11, 2020 6:58 pm ] |
Post subject: | Primary gears |
I have a few primary gears and am unsure if they are 1275 or something else. How do I determine if a primary gear is 1275 or not apart from physically sticking it on a 1275 crank? (Are all 1275 primary gears the same... ie mk1 S, mk2 S, 1100S etc) Brenton |
Author: | gtogreen1969 [ Mon May 11, 2020 7:04 pm ] |
Post subject: | Re: Primary gears |
Bubbacluby wrote: I have a few primary gears and am unsure if they are 1275 or something else. How do I determine if a primary gear is 1275 or not apart from physically sticking it on a 1275 crank? (Are all 1275 primary gears the same... ie mk1 S, mk2 S, 1100S etc) Brenton Send a PM to our resident expert - Richard Top bloke and always willing to help |
Author: | timmy201 [ Mon May 11, 2020 7:37 pm ] |
The small bore ones have the same diameter bush in each end. 1275 is bigger on the engine side bearing |
Author: | TK [ Mon May 11, 2020 7:39 pm ] |
all 1275 crank tails are the same. |
Author: | Morris 1100 [ Mon May 11, 2020 7:44 pm ] |
TK wrote: all 1275 crank tails are the same. I know of three different 1275 crank tails. ![]() |
Author: | Bubbacluby [ Mon May 11, 2020 8:00 pm ] |
So do small bore and 1275 primary gears have the same number of teeth? |
Author: | TK [ Mon May 11, 2020 8:02 pm ] |
yes I believe so. 998s machined will fit a 1275 |
Author: | Bill B [ Mon May 11, 2020 8:39 pm ] |
There might be some information here about 1275/998 primary gears: viewtopic.php?f=2&t=99457 |
Author: | Bubbacluby [ Mon May 11, 2020 9:11 pm ] |
Thankyou people for your replies. |
