Lucas headlamp identifiers https://ausmini.com/forums/viewtopic.php?f=2&t=99939 |
Author: | pdpsing [ Tue Apr 28, 2020 8:15 pm ] |
Post subject: | Lucas headlamp identifiers |
Picked up John Sneddon's excellent book on Australian built Minis. One thing I noticed is that the Lucas headlamps were upgraded in Oct 1969 from 60/45W to 70/55W. How can you tell the difference? I have some spare used Lucas sealed beam lamps and can't find anything obvious that identifies whether they are the 60/45's or 70/55's |
Author: | gtogreen1969 [ Tue Apr 28, 2020 8:37 pm ] |
Post subject: | Re: Lucas headlamp identifiers |
If there is no ink stamp on the back then you could use Ohms Law to work it out. You just need to measure your ohms readings. http://www.bowdenshobbycircuits.info/ohmslaw.htm |
Author: | pdpsing [ Tue Apr 28, 2020 8:44 pm ] |
Thanks, had forgotten my high school physics |
Author: | Dave Dobeson [ Tue Apr 28, 2020 9:44 pm ] |
Right logic, but the cold resistance that you might measure with a multimeter will appear to be much less than the hot resistance (about 2 ohms) when the wire is carrying 5 or 6 amps at 60 to 75 watts. This is also why most bulbs "blow" at switch on when current is much higher for the first fraction of a second. A more accurate method would be to connect the light to a car battery and measure the current (if your multimeter has a 10 amp setting). 5 amps => 60 watts and 6+ amps => 75 watts Don't leave the multimeter connected for more than a few seconds as 5 or 6 amps might heat it up. Dave D |
Author: | pdpsing [ Tue Apr 28, 2020 10:27 pm ] |
Thanks Dave Sent from my SM-A305YN using Tapatalk |
Author: | Dave Dobeson [ Wed Apr 29, 2020 11:12 am ] |
pdpsing I dug out two old Lucas sealed beam headlights and measured currents. 60/45 was 4.2 amps at 12.2 volts on highbeam and 2.6 amps at 12.3 volts on low. ?/? was 4.9 amps at 12.0 volts and 2.9 amps at 12.3 volts ( did not see brightness difference) The ?/? did have very dirty markings until I tried to wipe them..... bad idea. The 60/45 calculates at well below 60 Watts but I assume it is meant to have 13-14 volts in a running car, not 12.2 volts from an Aldi deep cycle. The cold resistances were about 0.5 ohms but multimeters were just guessing this low. |
Author: | pdpsing [ Wed Apr 29, 2020 12:17 pm ] |
Thanks Dave. Bought a multimeter this morning so I can test mine Sent from my SM-A305YN using Tapatalk |
