Thanks Bill and TK.
I seem to recall reading that with the QL's being more like a standard uni joint that the old rubber ones, there was no need to tighten them up under load. I think it mentioned that if the wheels were hanging in the air with the old rubber ones, there was undue tension on them - bit like the lower arms bushes on the front end if you do them up with the arm hanging right down.
Not sure if that's correct though. I may have things mucked up. It would definitely be easier if I could fit them all up without moving the car.
I've also read somewhere where you should have no more than 1/4" of thread showing past the nut. I did measure the length of thread past the yolk and the nut thickness but can't remember the measurements off hand so will check again tomorrow and let you know. I'll also measure the distance that 1 complete turn of the nut travels in order to maybe have a reference to how many turns are required to have 1/4" of thread.
I agree with you Bill that I'm over thinking it but I don't want to bugger it up if I can help it. Give me something to think about during lockdown.
Rocky
