It is currently Fri Jul 18, 2025 11:06 am
 Post subject: Best Airfilter
PostPosted: Fri Apr 24, 2020 6:51 pm
Whats the best Air Filter to use for a Cooper S Mk 2 and also part number
 Post subject: Re: Best Airfilter
PostPosted: Fri Apr 24, 2020 7:01 pm
I have these in my MK1 S. However it looks like the price has almost doubled since I bought mine.
https://www.knfilters.com/e-9001-replacement-air-filter
https://www.amazon.com/9001-High-Perfor ... B00062ZMVY
PostPosted: Sat Apr 25, 2020 4:31 am
Cheers :D Thank you gtogreen1969
Seems like there aren't many to pick from here these day's
PostPosted: Sat Apr 25, 2020 11:00 am
Ryco A256
PostPosted: Sat Apr 25, 2020 4:35 pm
I have just used standard paper filters for over 40 years. I assume that is what Stibbsy means.
PostPosted: Sun Apr 26, 2020 6:50 am
Thanks Bill B.
I have been using the standard filter but have come a cross the same filter which is about 10mm higher.
The part numbers have changed I think as I recall A389-Ryco made in NZ by G.U.D and then there is GFE 1038.
Just can't pop down to the parts shop these days to compare :?
I've ordered 2 Ryco A256 :|
Are the K and N Filter's E-9001 reusable? The seem to be a lot more expensive.
PostPosted: Sun Apr 26, 2020 10:19 am
The height of different air filters was discussed here:
viewtopic.php?f=2&t=95994&hilit=air+filters
if it helps.
I notice Karcraft have several different air filters, including a "thin" one for Cooper S specifically.
PostPosted: Sun Apr 26, 2020 11:50 am
Firefirey wrote:
Thanks Bill B.
Yes they are reusable and are supposed to flow a bit better. I dont think i would want to be paying the current prices. I bought mine from the states ages ago when the US dollar was almost the same as ours for a brief period.
