Flickering ignition light https://ausmini.com/forums/viewtopic.php?f=2&t=99924 |
Author: | pdpsing [ Thu Apr 23, 2020 6:31 pm ] |
Post subject: | Flickering ignition light |
Notice that the ignition light on my Mk2 S occasionally flickers at higher road (not engine) speeds, typically >50MPH. None of the alternator leads seem loose, so I am guessing that something loosens intermittently with the volume of air running through the grille. Any other likely explanation? If not, which is likely to be the offending lead? Maybe a dirty connection? |
Author: | drmini in aust [ Thu Apr 23, 2020 6:52 pm ] |
Post subject: | Re: Flickering ignition light |
The light flickering can be a warning that the brushes are wearing out. One wears faster than the other but you replace as a set. These are mounted external on an S, easy to replace in situ. Otherwise, probably a bad connection somewhere. |
Author: | pdpsing [ Thu Apr 23, 2020 7:15 pm ] |
Thanks Dr Mini, will check for bad connection first |
Author: | pdpsing [ Thu Apr 23, 2020 7:54 pm ] |
If it turns out to be brushes, the only supplier I can see is Minisport (SA) with their ABR5406/ULB110- Lucas Alternator brush set. Is this what I would need for a Mk2 Alternator? |
Author: | Bill B [ Thu Apr 23, 2020 10:07 pm ] |
For parts for 15AC alternators: Try Anthony Buttigieg trading as "Auto Electrics on Wheels" and listed in Ausmini businesses. He supplies a lot of mini related electrics as parts or complete units and is very willing to discuss problems. [email protected] 0408 731 441 Or (07) 5546 9065 Also check Ashdown Ingram Brush Set 9815 ( may not be still available) Also check Elecrical Rebuilders Group QLD (07) 3277 9377 ( speak to Allen Hill) for parts or rebuilds. |
Author: | pdpsing [ Thu Apr 23, 2020 10:32 pm ] |
Thanks Bill B Sent from my SM-A305YN using Tapatalk |
