It is currently Fri Jul 04, 2025 9:24 pm
PostPosted: Thu Apr 23, 2020 6:31 pm
Notice that the ignition light on my Mk2 S occasionally flickers at higher road (not engine) speeds, typically >50MPH. None of the alternator leads seem loose, so I am guessing that something loosens intermittently with the volume of air running through the grille. Any other likely explanation? If not, which is likely to be the offending lead? Maybe a dirty connection?
1970 Cooper S SPO41
PostPosted: Thu Apr 23, 2020 6:52 pm
The light flickering can be a warning that the brushes are wearing out.
One wears faster than the other but you replace as a set.
These are mounted external on an S, easy to replace in situ.
Otherwise, probably a bad connection somewhere.
PostPosted: Thu Apr 23, 2020 7:15 pm
Thanks Dr Mini, will check for bad connection first
1970 Cooper S SPO41
PostPosted: Thu Apr 23, 2020 7:54 pm
If it turns out to be brushes, the only supplier I can see is Minisport (SA) with their ABR5406/ULB110- Lucas Alternator brush set. Is this what I would need for a Mk2 Alternator?
1970 Cooper S SPO41
PostPosted: Thu Apr 23, 2020 10:07 pm
For parts for 15AC alternators:
Try Anthony Buttigieg trading as "Auto Electrics on Wheels" and listed in Ausmini businesses. He supplies a lot of mini related electrics as parts or complete units and is very willing to discuss problems.
[email protected]
0408 731 441
Or (07) 5546 9065
Also check Ashdown Ingram Brush Set 9815 ( may not be still available)
Also check Elecrical Rebuilders Group QLD (07) 3277 9377 ( speak to Allen Hill) for parts or rebuilds.
PostPosted: Thu Apr 23, 2020 10:32 pm
Thanks Bill B
Sent from my SM-A305YN using Tapatalk
1970 Cooper S SPO41
Users browsing this forum: carter, jpodge and 84 guests
