It is currently Sat Jul 05, 2025 12:34 am
PostPosted: Tue Feb 12, 2019 9:15 am
Hi guy's it's me again, I have been out sick for a while and my mini got sick too. I replaced my distributor with the original one and also upgraded to the electronic ignition (no points) I used a NGK BP6ES spark plug.
If I lean out the mixture the car would idle fine but hesitate when accelerating so I would richen the mixture a bit until it does not hesitate. Now my plugs are fouled.
My questions are:
1. Can I use the BP6ES with an electronic ignition or should I use the BPR6ES?
2. I did not replace my ignition coil when I upgraded to an electronic ignition, is there a specific ignition coil that I need to use? the ignition coil is the only component of the ignition system that is old.
Any help is appreciated.
1973 Clubman GT - YG2S8 1637
PostPosted: Wed Feb 13, 2019 7:45 am
Have you timed to distributor correctly? What is your advance set at?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Feb 13, 2019 8:09 am
If you use a thicker oil in the SU dashpot, it will enrich the mixture on acceleration. Too little, too thin or no oil will result in a lean mixture whenever you put your foot down.
PostPosted: Thu Feb 14, 2019 1:58 pm
Thanks for the inputs. I want to change my ignition coil? any recommendations?
PostPosted: Sat Feb 23, 2019 7:28 am
Check with the supplier of the Electronic Distributor you bought to see what Coil they recommend. if bought new the Distributor should come with Test Procedures and Instructions. Very important to use correct Ohms Value coil to suit the distributor. Coil failure most times occurs when they warm up meaning, when you test a coil 'cold' it will read good but when warm it can cause all weird and wonderful faults. Best is to find out what supplier suggests and buy a new coil. I always supply instructions and test procedures with my Electronic Distributors. always read and follow instructions. The old points can cop it from a Crook Coil but an Electronic Distributor module blows faster than a fuse when the coil is shorted and overloads it.
"Let us remove your "SHORTS"
PostPosted: Mon Feb 25, 2019 9:41 am
Maybe I did not explain it well but I bought only the part that goes into the original distributor that replaces the contact point. Not the whole distributor.
PostPosted: Mon Feb 25, 2019 10:34 am
The same principle applies: ask the supplier of the new electronic points what coil they recommend.
I bought mine at the same time and I bought the recommended coil so I knew they’d work together (from Tony / convertible mini)
PostPosted: Mon Feb 25, 2019 10:51 am
GuamMini - What brand/model electronic ignition kit did you buy and where from?
PostPosted: Mon Feb 25, 2019 3:36 pm
RTC3875K - Mini electronic ignition kit 25D/29D)- BRITPART'S BRAND
I bought it from Minisport AUS
PostPosted: Mon Feb 25, 2019 5:12 pm
Here's what you bought - https://minisport.com.au/mini-electroni ... arts-brand
You'll see there's a link to INSTRUCTIONS just below the description. If you click on that it says, among other things, that a standard coil can be used. :wink:
PostPosted: Tue Feb 26, 2019 8:47 am
Awesome thank you for the help. Based on this what is the best standard ignition coil? mine is quite old and mounted above the starter. When I get a new coil I will mount it behind the Alternator as it should be.
PostPosted: Tue Feb 26, 2019 3:38 pm
After being let down by a couple of modern coils I use an ancient, crusty but trusty GT40 coil I had lying around. I have the same electronic ignition kit.
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Tue Feb 26, 2019 3:53 pm
Is the GT40 coil a Bosch unit?
PostPosted: Tue Feb 26, 2019 8:56 pm
Yes
5/72 Clubman Gt
PostPosted: Wed Feb 27, 2019 7:08 am
I have brand new Compatible Coils for these Red Module Electronic Ignition kits and Distributors.
They cost $48 each plus post.
