Diff output cover running clearance. https://ausmini.com/forums/viewtopic.php?f=2&t=99876 |
Author: | iansmini67 [ Mon Apr 13, 2020 6:41 pm ] |
Post subject: | Diff output cover running clearance. |
I have needed to replace the diff output side cover bearings on my S box and the new ones require reaming. Does anybody know the running clearance for these. Running Hardy Spicer couplings. ![]() Sent from my SM-G965F using Tapatalk |
Author: | Ian_B [ Mon Apr 13, 2020 6:47 pm ] |
Post subject: | Re: Diff output cover running clearance. |
The Doc will know |
Author: | gtogreen1969 [ Mon Apr 13, 2020 8:18 pm ] |
Go for 4 or 5 thou, 1 or 2 thou is too tight |
Author: | iansmini67 [ Mon Apr 13, 2020 8:22 pm ] |
Thanks for the reply. Will go with 5 thou. Sent from my SM-G965F using Tapatalk |
Author: | drmini in aust [ Tue Apr 14, 2020 7:03 am ] |
5 thou is too much, I bore them in the lathe to .002" clearance. If they bind something is pushing the drive flange out of line, probably a bent collet inside it. |
Author: | gtogreen1969 [ Tue Apr 14, 2020 9:53 am ] |
Go with the Docs measurement. Dont worry about me - i was thinking of the freeplay when they are rocked back and forth. |
