Noise in Front end. https://ausmini.com/forums/viewtopic.php?f=2&t=99829 |
Page 1 of 3 |
Author: | Flying Brick [ Wed Apr 08, 2020 5:12 pm ] |
Post subject: | Noise in Front end. |
Hi, Just wondering if anyone has an idea as to where the noise is coming from in my front end. I thought it was a wheel bearing on the left side as it had a bit of play, I replaced it and still the same. I then thought it could be diff or something in that area. I changed engine, gearbox and drive shafts and still the same. (engine needed changing anyway). I changed the other wheel bearing to see but still the same. Noise is like a wheel bearing, its not the engine, i can turn the engine off and it is still there. Any ideas would be appreciated. Thanks. Steve |
Author: | TK [ Wed Apr 08, 2020 5:49 pm ] |
Post subject: | Re: Noise in Front end. |
Maybe CV? universal? who knows? |
Author: | Flying Brick [ Wed Apr 08, 2020 6:16 pm ] |
Thanks Tk, It had cv joints in it before I changed the engine and gearbox and now has universals . Sound is the same. Steve |
Author: | 850_Van [ Wed Apr 08, 2020 7:24 pm ] |
Could it be brake related? As in the pad or brake lining dragging? |
Author: | IndigoBlueCooperS [ Wed Apr 08, 2020 9:16 pm ] |
Does the noise change when you apply brake pressure? |
Author: | Flying Brick [ Wed Apr 08, 2020 9:30 pm ] |
It doesn't change no but i guess it is something to check. Maybe a cylinder is stuck, but i would think the shoe would wear away. The noise has not changed for a while. I will have look at that over the weekend hopefully. Steve |
Author: | 3ug3 [ Thu Apr 09, 2020 9:34 am ] |
Diff. Or drop gears? I’ve got no idea what I’m talking about by the way. Just thinking what else turns on bearings that sounds like wheel bearing grinding noise. Gear box? Sent from my iPhone using Tapatalk |
Author: | TK [ Thu Apr 09, 2020 11:02 am ] |
So the mini made the strange noise. Then changed the engine, gearbox and driveshafts so we can rule those out as it is still making the mystery sound. It's not CVs as the owner said that they are new. The only things left are wheels, the right hand wheel bearings, brake drums....... jack the car up and spin the wheel is it slightly buckled? Is there a drag on the brake drum? How does that right hand side sound when turning the wheel? |
Author: | Flying Brick [ Thu Apr 09, 2020 11:49 am ] |
Thanks, I have changed both wheel bearings now, still the same noise. I will jack it up this weekend hopefully and check the brakes. The brakes are all i can think it is now. I will post back with anything i find. Steve. |
Author: | TK [ Thu Apr 09, 2020 1:29 pm ] |
are you positive that it's coming from the front? |
Author: | drmini in aust [ Thu Apr 09, 2020 2:40 pm ] |
Ball or roller bearings? If the latter, Timkens or noname? Many noname ones come with an incorrect spacer, if too thin it overloads the bearings when the hub nut is torqued up. See my blog in the how to forum. |
Author: | Flying Brick [ Fri Apr 10, 2020 10:05 am ] |
The noise is almost certainly coming from the front. I thought it could be coming from the back and somehow getting transferred to the front but i dont think thats the case. The bearings are just standard ball bearings, with the built in spacers. Steve. |
Author: | 9YaTaH [ Fri Apr 10, 2020 10:10 am ] |
Fan touching shroud? |
Author: | TK [ Fri Apr 10, 2020 10:12 am ] |
Can you post a video? |
Author: | Bill B [ Fri Apr 10, 2020 11:27 am ] |
Can the brake shoe return springs be put on wrong way round so the middle part of the spring rubs on the hub, like they can at the rear hubs? |
Page 1 of 3 | All times are UTC + 10 hours |
