More bits to identity (only 6) https://ausmini.com/forums/viewtopic.php?f=2&t=99819 |
Author: | 68AUTO [ Sun Apr 05, 2020 5:15 pm ] |
Post subject: | More bits to identity (only 6) |
Hi, I have six more bits to identify... and then the rest can go in a box for the time being. In the last lot ALL Mini bits were identified and there were a few unknowns and questionables. I have tried to search for these beforehand with no luck. Already found: 1. Distributor to block flange 2. Oil pressure sender - electric gauge 3. Hydro hose nylon protector sleeve retainer 4. Speedo drive worm. Engages 3rd motion shaft in gearbox. Attachment: IMG_0001.jpg
Author: | timmy201 [ Sun Apr 05, 2020 5:42 pm ] |
Post subject: | Re: More bits to identity (only 6) |
1. Distributor to block flange 2. Oil pressure sender - electric gauge |
Author: | winabbey [ Sun Apr 05, 2020 5:43 pm ] |
1. Distributor mount 3. Hydro hose nylon protector sleeve retainer |
Author: | drmini in aust [ Mon Apr 06, 2020 5:56 am ] |
4. Speedo drive worm. Engages 3rd motion shaft in gearbox. |
Author: | sitnlo62 [ Wed Apr 08, 2020 6:53 pm ] |
drmini in aust wrote: 4. Speedo drive worm. Engages 3rd motion shaft in gearbox. Sorry but I don't believe that is correct. The gear you are thinking of has a shorter shaft with flats on the end to allow it to fit in the end of the 3rd motion shaft. Maybe a similar part from a different BMC gearbox though. |
Author: | drmini in aust [ Wed Apr 08, 2020 7:26 pm ] |
sitnlo62 wrote: drmini in aust wrote: 4. Speedo drive worm. Engages 3rd motion shaft in gearbox. Sorry but I don't believe that is correct. The gear you are thinking of has a shorter shaft with flats on the end to allow it to fit in the end of the 3rd motion shaft. Maybe a similar part from a different BMC gearbox though. You are right, I didn't look close enough. ![]() Maybe Morris 1500? or 1800? Dunno... |
Author: | Morris 1100 [ Wed Apr 08, 2020 8:14 pm ] |
It looks like the speedo drive out of an automatic. |
Author: | ozmini [ Thu Apr 09, 2020 5:38 am ] |
5. Internal Mirror mount. Glues to screen and mirror foot slides over it. |
