It is currently Sat Jul 05, 2025 10:09 pm
 Post subject: Oil pressure dropping
PostPosted: Fri Mar 27, 2020 3:38 pm
G'day mini nerds,
I'm having an issue with the oil pressure on my 850 mk1 project, I've got a pressure gauge thet reads 50lb when the engine first starts up although as it gets a bit hotter and revs, it goes down to about 15-20lb. I have some air in the oil pressure line although I figure that if it starts high (50lb) this may not be the issue. Am I going to have to change my oil pump or is this just a matter of bleeding the oil pressure line.
I've attached photos.
Cheers mini maniacs.
PostPosted: Fri Mar 27, 2020 3:44 pm
Online
The oil will always lose pressure as it heats up. My old engine had similar oil pressure readings at idle, it was just worn out and probably needed new bearings and oil pump.
It should increase the oil pressure with RPM, about 10psi per 1000rpm. Bleeding is not critical and will drive you bonkers
PostPosted: Fri Mar 27, 2020 4:02 pm
Awesome. Thank you mate. I'll keep an eye on it and make sure it doesn't go to 0. I still haven't given it a good run yet so hopefully it goes back up.
Thanks again
PostPosted: Fri Mar 27, 2020 4:09 pm
What oil are you using? How long has it been in there?
PostPosted: Fri Mar 27, 2020 4:31 pm
I'm using a "gulf western" 20W-50 SN/CF and it's been in there for about 6 months but I've only turned it over about 5 times since putting it in
PostPosted: Fri Mar 27, 2020 4:36 pm
Try some HPR30 tends to hold its pressure once it heats up .
PostPosted: Fri Mar 27, 2020 4:41 pm
Pressure that low it needs a rebuild.
PostPosted: Fri Mar 27, 2020 4:43 pm
Awesome. I'll try the HPR30 before going the rebuild route. Hopefully that holds it all together. Thanks guys
PostPosted: Fri Mar 27, 2020 6:06 pm
or an oil pump...
PostPosted: Fri Mar 27, 2020 7:25 pm
or checked the accuracy of the oil pressure gauge.
PostPosted: Fri Mar 27, 2020 7:52 pm
We had low oil pressure and a rebuild was recommended.
Pulled out the oil relief valve to find that it wasn’t seating properly.
Bought a new valve and spring , and bingo, all good.
PostPosted: Sat Mar 28, 2020 4:18 pm
This is all awesome stuff. Thank you guys. I changed the oil which helped a bit but it ended up back at 20 anyway. I will try all of this in the desperate attempt to avoid a rebuild.
You guys are the best.
Cheers again
PostPosted: Sat Mar 28, 2020 4:29 pm
Try the pressure relief valve.
PostPosted: Sat Mar 28, 2020 4:36 pm
I definitely will. I'll start looking at that tomorrow. This quarantine stuff is great for my mini
PostPosted: Sat Mar 28, 2020 4:48 pm
Online
Mine lasted a couple of years with it that low. I changed to the 20/60 HPR and bumped up the idle to 1500rpm. Not recommend for long term health of the engine though :lol:
Users browsing this forum: timmy201 and 96 guests
