https://ausmini.com/forums/
Oil Pump Bolts
https://ausmini.com/forums/viewtopic.php?f=2&t=99778
Author:  slide [ Sun Mar 22, 2020 6:16 pm ]
Post subject:  Oil Pump Bolts
Replacing pin drive oil pump in my S engine. The new pump is Mini Spares C-AEG410 which has four bolt holes. The old pump was a three bolt HE type pump (Birmingham 5367-C stamped on the body) and the bolts were secured with a half moon all in one lock washer.
The body on the old pump was slightly wider than the MS one meaning the old bolts are too long and bottom out. I can cut the old bolts down a bit to overcome this, but the old lock washer won't fit of course. Did the four bolt pumps use spring washers under the bolt heads? no washers? or was there a special all in one lock washer set up for this pump too?
Author:  drmini in aust [ Mon Mar 23, 2020 4:49 am ]
Post subject:  Re: Oil Pump Bolts
Fit new spring washers and shorten the bolts.
For peace of mind you could Loctite the threads but I've never had them come loose.
Author:  slide [ Mon Mar 23, 2020 4:40 pm ]
Thanks Doc, I didn't think there was a continuous lock tab washer for the 4 bolt pumps.
