https://ausmini.com/forums/
Hose/pipe for hydrolastic pump?
https://ausmini.com/forums/viewtopic.php?f=2&t=99771
Author:  rodmac [ Fri Mar 20, 2020 2:56 pm ]
Post subject:  Hose/pipe for hydrolastic pump?
Hi everyone,
When pumping up my suspension last week the hose from the pump to the schrader valve spilt.
Can anyone advise on what the best hose to replace it with is and where I can get it?
Thanks
Rod
Author:  drmini in aust [ Fri Mar 20, 2020 4:37 pm ]
Post subject:  Re: Hose/pipe for hydrolastic pump?
My pump is home made, I use Mini front brake hoses.
Any brake hose would do, maybe take the remains to a brake shop. They can make custom hoses.
Author:  Andosoft [ Fri Mar 20, 2020 5:32 pm ]
I have a grease gun pump. Grease gun flex extension rated to 1500psi with Schrader valve adapter attached
Author:  Bill B [ Sat Mar 21, 2020 10:41 am ]
The repair kit mentioned by Richard was originally supplied by Fischer-Cripps Laboratories P/L in Sydney.
At one stage Tony Cripps offered to supply any individual parts for the Churchill pump as well as a complete kit. I don't know if the offer is still available.
I would think any hydraulics shop could supply the hose but if you want the hose from the overhaul kit, the best contact details I can find for them is:
https://www.azom.com/suppliers.aspx?SupplierID=11429
Author:  Morris 1100 [ Sat Mar 21, 2020 12:41 pm ]
It is nylon air brake hose which you can get from Pirtek or Enzed or most large truck repair shops.
