It is currently Mon Jul 07, 2025 3:25 pm
 Post subject: 10x4.5 steel wheels?
PostPosted: Sat Dec 21, 2019 3:45 pm
Hi all,
I want to run 10" steel wheels with 165 tyres and no flares so I guess I need 4.5" wide wheels?
Are the 9 hole S wheels the only option or are there other suitable steelies around?
 Post subject: Re: 10x4.5 steel wheels?
PostPosted: Sat Dec 21, 2019 3:48 pm
LS offset Contessas are what people often use.
Sent from my SM-N960F using Tapatalk
PostPosted: Sat Dec 21, 2019 4:03 pm
Thank. I have a set of those, but want to use steel wheels instead.
PostPosted: Sat Dec 21, 2019 4:05 pm
Oh sorry. I didn't read the heading properly before replying.
165 tyres will fit on standard steelies.
Some standard steelies will also clear 7.5 discs also, but a lot won't, so keep that in mind.
PostPosted: Sat Dec 21, 2019 4:06 pm
There’s not much option in 4.5” steels. There’s Cooper S or Clubman GT wheels and then older wheels that have been customised
If you like the look of steel wheels you can also get the alloy copies
https://minisport.com.au/mini-10x45-coo ... set-4-rims
PostPosted: Sat Dec 21, 2019 6:19 pm
standard clubman S wheels are 4.5" - dime-a-dozen - I gave 2 sets away for a bottle of JD earlier this year
PostPosted: Sun Dec 22, 2019 12:37 pm
The clubman wheels won't look right.
I'll have to pick up some S wheels I guess.
Tha ks everybody :)
PostPosted: Sun Dec 22, 2019 2:54 pm
Thanks everybody :)
or something like these:
https://www.minimania.com/part/21A1282/ ... eel-Silver
https://www.minimania.com/part/21A1286M ... 5-Aluminum
PostPosted: Sun Dec 22, 2019 10:18 pm
Don’t forget you can’t run S wheels with standard drums :|
Cheers, Ian
PostPosted: Mon Feb 03, 2020 4:32 pm
Were any of the standard type steel wheels available in 4.5”? I am considering putting the original 850 type wheels on mine, but I’d prefer to have A008’s
These are listed as 4.5”, I’m not sure if this is a mistake?
https://minisport.com.au/mini-10x45-ste ... andblasted
These have 165 tyres and don’t look like the tyres are too ballooned? They don’t appear to be widened
https://www.gumtree.com.au/s-ad/camden- ... 1240283217
PostPosted: Tue Feb 04, 2020 3:58 am
3.5" Mini wheels are too narrow for 165/70 tyres.
Handling is crap.
Use 145/80-10 instead, however there is not much tyre choice now. Falken or ??
Users browsing this forum: BBY755 and 93 guests
