https://ausmini.com/forums/
Gearbox Remote change
https://ausmini.com/forums/viewtopic.php?f=2&t=99615
Author:  crisonic [ Tue Jan 21, 2020 3:56 pm ]
Post subject:  Gearbox Remote change
Can any tell me how to set up the rod and end fittings on an early remote change
It is the relationship of the knuckle where the gear lever ball fits and the angle of the fork ends where the remote bolts onto the gearbox.Are these 2 fitting in line or one spline offset.
Author:  Stibbsy [ Tue Jan 21, 2020 5:02 pm ]
Post subject:  Re: Gearbox Remote change
Hope this helps
Author:  Stibbsy [ Tue Jan 21, 2020 5:04 pm ]
That is one spline or 10 deg.
Author:  crisonic [ Tue Jan 21, 2020 9:28 pm ]
Thanks 848 . The picture you posted is out of the Australian Workshop Manual. The reason I asked is if you read the paragraph next to the drawing it states
"When fitting the lever to the shaft ensure that the lever is positioned in the same vertical plane as the primary shaft" Quote unquote
It appears that the written word and the drawing are in conflict
Which is the reason for the question
Anybody with further comments?
Author:  drmini in aust [ Wed Jan 22, 2020 4:00 am ]
Both mine are in line.
Edit:
Gear lever should be vertical in the 3-4 plane, if not it's easiest to move the RH knuckle on its spline, above the diff housing.
Author:  crisonic [ Wed Jan 22, 2020 8:58 am ]
Thanks Doctor
Author:  Stibbsy [ Thu Jan 23, 2020 1:28 pm ]
I think mine are in line also, but sometimes 1st gear is not a positive engagement. I wonder if that is why.
