It is currently Mon Jul 07, 2025 10:23 pm
 Post subject: Engine bay wiring
PostPosted: Sat Jan 04, 2020 8:15 am
I'm looking at running the new wiring loom (hot rod kit not orginal) into the engine bay. Searching around it looks like the orginal wiring come out if the speedo hole and ran along the top of the firewall then down the drivers side, like in picture below, is that correct?
Also what other tricks have you used for hidden wiring?
Thank you in advance.
 Post subject: Re: Engine bay wiring
PostPosted: Sat Jan 04, 2020 9:17 am
The path you show is the correct original way. You should find flat clips spot welded along this route that hold the loom in place.
PostPosted: Sat Jan 04, 2020 3:15 pm
Thanks Winabbey
PostPosted: Sat Jan 04, 2020 7:03 pm
I started running mine back into the firewall behind the master cylinders then into and out of the fresh air pipe in the guard. Most of the wiring was plenty long enough. Ill probably move the starter solenoid too, but dunno where yet.
I would say it would have been easier to stay behind the dash cards but i didn't want to pull too much out.
Sent from my Nokia 5.1 Plus using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Tue Jan 07, 2020 2:26 pm
Thanks Blue, do you mean yo ran it in the fresh air pipe? Do you have any pics?
PostPosted: Tue Jan 07, 2020 3:45 pm
Like i said would have been easier to stay behind the dash. Ive figured how to cut and bend the air pipes around the split conduit so it won't leak air. The conduit will protect the exposed sections. There are loads of holes for the wires to poke back through where needed.i shortened a few wires and extended a few, and moved the fuses so they'll be hidden too. Ive got relays and a solenoid to move still.
PostPosted: Wed Jan 08, 2020 9:51 am
Thanks for that looks good, Yeah I can hide behind the currently non existent dash cards.
PostPosted: Wed Jan 15, 2020 8:14 pm
Hidden wiring is done when the owner is doing a crap job himself and does not want any one to see it.
"Let us remove your "SHORTS"
PostPosted: Wed Jan 15, 2020 8:26 pm
*insert laugh track*
