10x4.5 steel wheels? https://ausmini.com/forums/viewtopic.php?f=2&t=99544 |
Author: | ben73 [ Sat Dec 21, 2019 3:45 pm ] |
Post subject: | 10x4.5 steel wheels? |
Hi all, I want to run 10" steel wheels with 165 tyres and no flares so I guess I need 4.5" wide wheels? Are the 9 hole S wheels the only option or are there other suitable steelies around? Thanks ![]() |
Author: | Bubbacluby [ Sat Dec 21, 2019 3:48 pm ] |
Post subject: | Re: 10x4.5 steel wheels? |
LS offset Contessas are what people often use. Sent from my SM-N960F using Tapatalk |
Author: | ben73 [ Sat Dec 21, 2019 4:03 pm ] |
Thank. I have a set of those, but want to use steel wheels instead. |
Author: | Bubbacluby [ Sat Dec 21, 2019 4:05 pm ] |
Oh sorry. I didn't read the heading properly before replying. 165 tyres will fit on standard steelies. Some standard steelies will also clear 7.5 discs also, but a lot won't, so keep that in mind. Sent from my SM-N960F using Tapatalk |
Author: | timmy201 [ Sat Dec 21, 2019 4:06 pm ] |
There’s not much option in 4.5” steels. There’s Cooper S or Clubman GT wheels and then older wheels that have been customised If you like the look of steel wheels you can also get the alloy copies https://minisport.com.au/mini-10x45-coo ... set-4-rims |
Author: | simon k [ Sat Dec 21, 2019 6:19 pm ] |
standard clubman S wheels are 4.5" - dime-a-dozen - I gave 2 sets away for a bottle of JD earlier this year |
Author: | ben73 [ Sun Dec 22, 2019 12:37 pm ] |
The clubman wheels won't look right. I'll have to pick up some S wheels I guess. Tha ks everybody ![]() |
Author: | 9YaTaH [ Sun Dec 22, 2019 2:54 pm ] |
ben73 wrote: The clubman wheels won't look right. I'll have to pick up some S wheels I guess. Thanks everybody ![]() or something like these: https://www.minimania.com/part/21A1282/ ... eel-Silver https://www.minimania.com/part/21A1286M ... 5-Aluminum |
Author: | 1071 S [ Sun Dec 22, 2019 10:18 pm ] |
Don’t forget you can’t run S wheels with standard drums ![]() Cheers, Ian |
Author: | timmy201 [ Mon Feb 03, 2020 4:32 pm ] |
Were any of the standard type steel wheels available in 4.5”? I am considering putting the original 850 type wheels on mine, but I’d prefer to have A008’s These are listed as 4.5”, I’m not sure if this is a mistake? https://minisport.com.au/mini-10x45-ste ... andblasted These have 165 tyres and don’t look like the tyres are too ballooned? They don’t appear to be widened https://www.gumtree.com.au/s-ad/camden- ... 1240283217 Attachment: C499A2AB-2097-40D5-B88D-9866D98374E2.jpeg
Author: | drmini in aust [ Tue Feb 04, 2020 3:58 am ] |
3.5" Mini wheels are too narrow for 165/70 tyres. Handling is crap. Use 145/80-10 instead, however there is not much tyre choice now. Falken or ?? |
