It is currently Wed Jul 09, 2025 4:25 pm
PostPosted: Wed Dec 11, 2019 9:24 pm
I've heard that there are 2 different series of gearboxes and engines on the A series. So is this true?
PostPosted: Thu Dec 12, 2019 8:54 am
Online
Depending on what you mean by "series" there are many variations in the gearboxes: types of bearings; types of synchromesh; gear ratios; gear change methods; gear teeth shape, etc.
Perhaps you might mean the difference between early gearboxes with synchromesh on only the top 3 gears vs later 4 speed synchromesh?
Early gearboxes had 'A' type gear teeth and later ones were (you guessed it) 'B' type.
Engines went through a similar evolution and change over the production run of minis.
PostPosted: Thu Dec 12, 2019 9:40 am
The other way to look at the question is:
direct change gearbox (pudding stirrer gear lever)
remote change gearbox (remote gear lever, and
rod change gearbox (rod change lever)
PostPosted: Fri Dec 13, 2019 2:16 pm
Dont forget, you can also get
5 speed Helical A+
5 Speed Straight Cut A+
and even an 6 speed box from Italy all in a same casing
PostPosted: Sat Dec 14, 2019 3:44 am
Also some 5 and 6 speed straight cut boxes were made by KG Engineering in Melbourne years ago.
PostPosted: Sat Dec 14, 2019 6:17 am
Not to mention the dreaded Jack Knight :roll:
PostPosted: Sat Dec 14, 2019 10:09 am
And the differences between A-series and A+
PostPosted: Sat Dec 14, 2019 12:38 pm
Online
Unless Woody_Woodvine refines his question we could be here for a long time....
PostPosted: Sat Dec 14, 2019 1:26 pm
:D :D
PostPosted: Sat Dec 14, 2019 5:07 pm
Series 1 = Manual.
Series 2 = Auto.
PostPosted: Sat Dec 14, 2019 5:21 pm
How about transverse and inline gearboxes.
I am loving this thread
PostPosted: Sun Dec 15, 2019 1:04 pm
Well I've counted 8 different transverse gearboxes and 2 inline in my stash. That's without any of the exotic 5 & 6 speeds!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
Users browsing this forum: Bill B and 93 guests
