It is currently Wed Jul 09, 2025 12:24 am
PostPosted: Sun Dec 01, 2019 11:31 am
Hi all,
I will be looking to rebuild the front end in the new year on my (not so) 850.
Looking to add adjustable Caster bars and new LCA's...
I am a little perplexed if to go 1.5, 2deg or fully adjustable on the LCA. The car is only a road car, but aiming for a Cafe Racer type look/set up.
Any tips or advice would be appreciated.
Sent from my SM-G960F using Tapatalk
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Sun Dec 01, 2019 11:56 am
I'm happy with fixed 1.5 bottom arms and adjustable tie bars on the wasaMatic. Tyres are A008s.
I had previously bought Minispares adjustable LCAs but then thought they looked a bit weak. Minisport ones seem stronger to me, after fitting a few sets for friends.
PostPosted: Sun Dec 01, 2019 12:08 pm
I would go fixed 1.5 lower arms if your camber is even already. If your suspension is quite different from left to right then adjustable would be a better option.
Your correct about needing adjustable tie bars because the castor will change when the camber changes.
PostPosted: Sun Dec 01, 2019 12:34 pm
Don’t forget to order the extended steering tie rod ends too. As you make the lower arm longer the stock ends can run out of thread.
I added the adjustable ones to mine as they came up for a good price, but the fixed ones are obviously a bit more sturdy
