Adjustable Lower Control Arms https://ausmini.com/forums/viewtopic.php?f=2&t=99501 |
Author: | MINIRO [ Sun Dec 01, 2019 11:31 am ] |
Post subject: | Adjustable Lower Control Arms |
Hi all, I will be looking to rebuild the front end in the new year on my (not so) 850. Looking to add adjustable Caster bars and new LCA's... I am a little perplexed if to go 1.5, 2deg or fully adjustable on the LCA. The car is only a road car, but aiming for a Cafe Racer type look/set up. Any tips or advice would be appreciated. Sent from my SM-G960F using Tapatalk |
Author: | drmini in aust [ Sun Dec 01, 2019 11:56 am ] |
Post subject: | Re: Adjustable Lower Control Arms |
I'm happy with fixed 1.5 bottom arms and adjustable tie bars on the wasaMatic. Tyres are A008s. I had previously bought Minispares adjustable LCAs but then thought they looked a bit weak. Minisport ones seem stronger to me, after fitting a few sets for friends. |
Author: | gtogreen1969 [ Sun Dec 01, 2019 12:08 pm ] |
I would go fixed 1.5 lower arms if your camber is even already. If your suspension is quite different from left to right then adjustable would be a better option. Your correct about needing adjustable tie bars because the castor will change when the camber changes. |
Author: | timmy201 [ Sun Dec 01, 2019 12:34 pm ] |
Don’t forget to order the extended steering tie rod ends too. As you make the lower arm longer the stock ends can run out of thread. I added the adjustable ones to mine as they came up for a good price, but the fixed ones are obviously a bit more sturdy |
