It is currently Tue Jul 08, 2025 8:15 pm
 Post subject: Head stud hole
PostPosted: Tue Nov 26, 2019 3:54 pm
Broke a stud torquing the head down. Don't ask. Is this hole workable? Took about a mm of the top thread.
Sent from my Nokia 5.1 Plus using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
 Post subject: Re: Head stud hole
PostPosted: Tue Nov 26, 2019 4:43 pm
It's fine.
PostPosted: Tue Nov 26, 2019 4:47 pm
It's fine.
Make sure there are no high spots around the stud holes, they cause gasket leaks.
Was the stud a new one? Recent loose ones sold are poor quality.
Best to buy a set of competition ones for reliability.
Eg. ARP or minispares ones.
PostPosted: Tue Nov 26, 2019 5:25 pm
It was new. It spun in the block then busted while the torque wrench was at 47 lbs. Im a little cranky.
PostPosted: Wed Nov 27, 2019 2:52 pm
That should do it.
PostPosted: Fri Nov 29, 2019 3:35 pm
A decent chamfer will clean that up. Bolts exert most of their force on the first 3 threads, the deeper you make it the more uniform the clamping load.
History proves threading to the top is completely satisfactory however.
PostPosted: Fri Nov 29, 2019 7:06 pm
Please always check the length of the bolt/stud with the thickness of the head too.
Users browsing this forum: cruiser23 and 80 guests
