Installing velocity stacks https://ausmini.com/forums/viewtopic.php?f=2&t=99492 |
Author: | bamnfi [ Tue Nov 26, 2019 1:37 pm ] |
Post subject: | Installing velocity stacks |
I need some help. I have just bought a pair of velocity stacks for Claude, my MK 1 970cc Cooper S. When I had a quick look at the current setup I saw that the carbie return spring was attached to the air cleaner box. So where the heck do I attach that with the stacks installed? Thanks in anticipation. |
Author: | timmy201 [ Tue Nov 26, 2019 2:17 pm ] |
Post subject: | Re: Installing velocity stacks |
You can flip the spring to go down onto the bottom bar |
Author: | bamnfi [ Tue Nov 26, 2019 3:18 pm ] |
Well that makes sense. Thanks for that. |
Author: | 1071 S [ Thu Nov 28, 2019 2:19 pm ] |
Or just leave the third one off ..depending on how you like the throttle pedal to feel...... Cheers, Ian |
Author: | bamnfi [ Fri Nov 29, 2019 8:15 am ] |
Thanks Ian. Methinks I will go with a light pedal. |
