https://ausmini.com/forums/
2 speed wiper wiring - help!
https://ausmini.com/forums/viewtopic.php?f=2&t=99446
Author:  Gambo [ Fri Nov 01, 2019 9:03 am ]
Post subject:  2 speed wiper wiring - help!
One for the brains trust...
I'm trying to hook up my 2 speed wiper motor but am getting nowhere. I've followed the how to guide but it hasn't helped.
I think I may be missing a wire....and my sanity
Here is what I have:
At the wiper, 4 wires: Black, Red/Green, Green, Black/Green.
At the switch, Black, Red/Green, Black/Green.
Switch is definitely a 2 speed switch (part numbers are 35927/P94317) and has 6 terminals numbered 1,2,4,6,7,8.
When I hook it up as per the how to guide for 2 speed wiring, all i get is a single speed in the middle switch position with no parking. Switch in bottom position turns the motor off, again no parking. I have made sure to earth the motor body to the car body securely as well.
In the how-to wiring diagram, there looks to be a 4th wire going from the switch to the motor which I seem to be missing from my loom. I tried just running a temp wire to see if I could get it working but no go.
I've tried multiple combinations of wiring as well but still no joy.
Any suggestions folks?
Author:  DavidE [ Fri Nov 01, 2019 9:16 am ]
Post subject:  Re: 2 speed wiper wiring - help!
You need a Blue/Green wire from terminal 8 of the switch to the wiper motor (as shown). If you don't have one, run one.
Author:  Gambo [ Fri Nov 01, 2019 9:22 am ]
Tried that - made no difference.....
Author:  drmini in aust [ Fri Nov 01, 2019 9:34 am ]
Are the 3 copper fingers making good contact with the slip ring underneath?
Is the slip ring corroded at all?
Author:  Gambo [ Fri Nov 01, 2019 9:48 am ]
New stainless ring installed (thanks Convertible Mini) and the fingers seem to be making good contact.
Author:  drmini in aust [ Fri Nov 01, 2019 10:11 am ]
Have you checked it since fitting, these fingers lead not trail, and the park one can get bent bad if the slip ring is thicker than the plastic lug. I had to chamfer the slot (slip ring from John Smidt) as it was thicker.
Author:  Gambo [ Fri Nov 01, 2019 10:52 am ]
Will double check it this weekend, the new ring seemed to fit the drive gear OK though.
Bloody frustrating, last bit of electrical work that needs to be done....
Author:  BBY755 [ Fri Nov 01, 2019 6:23 pm ]
The last 1% usually causes 99% of the stress!
Author:  Gambo [ Fri Nov 01, 2019 6:40 pm ]
Not bloody wrong! I’m at the last 20% of the build taking 80% of the time stage. I just want to finish the damn thing.
Author:  slide [ Sat Nov 02, 2019 11:19 am ]
If you want to retain the original wiper motor then you don't have much choice but to keep trying to get it to work. I too spent ages on mine and got nowhere, in the end I swapped in the UK version with the park switch from MS. Works every time now.
Author:  Gambo [ Sat Nov 02, 2019 4:38 pm ]
After making a sacrifice to the Lucas Electrics gods, I pulled the wiper motor apart and checked/cleaned it completely.
Seems to have done the trick as the bloody thing works now.... I did have to add a wire from switch pin 8 to the motor, but I’ve got 2 speeds and self parking!
Author:  drmini in aust [ Sat Nov 02, 2019 5:40 pm ]
Good to hear it's sorted. :)
Maybe a brush was sticking in its holder.
Author:  DavidE [ Sat Nov 02, 2019 5:57 pm ]
Of course, else you don't get the second speed.
Author:  Gambo [ Sun Nov 03, 2019 9:17 am ]
When I ordered my loom I mustn’t have specified the 2 speed wiper, hence the need for the additional wire.
