https://ausmini.com/forums/
Fitting valve seat inserts -VIC
https://ausmini.com/forums/viewtopic.php?f=2&t=99422
Author:  Frog Johnson [ Mon Oct 21, 2019 9:47 pm ]
Post subject:  Fitting valve seat inserts -VIC
Looking for recommendations for someone to fit inserts in Melbourne- East or Peninsula, but will go anywhere.
The horror stories associated with poorly fitted seats popping out have spooked me somewhat, so I definitely want someone that will shrink them in with the correct interference etc.
Also - I got some from Minispares for a look and the internal diameter is about 1mm smaller than the existing seat. I assume you grind it out after fitting to suit the valve being used, but how far can you go? I was going to use 30mm MED valves
Author:  850man [ Tue Oct 22, 2019 4:43 am ]
Post subject:  Re: Fitting valve seat inserts -VIC
Talk to Link Automotive in Mitcham.
