Canberra mini mechanic https://ausmini.com/forums/viewtopic.php?f=2&t=99420 |
Page 1 of 2 |
Author: | benwantsamini [ Sun Oct 20, 2019 7:44 pm ] |
Post subject: | Canberra mini mechanic |
Hi all, I have been building a mini from ground up for the last three years. I am now at the pointy end and need a mechanic/auto elec in/around Canberra who knows minis to take it over the line. Any help would be greatly appreciated. |
Author: | simon k [ Mon Oct 21, 2019 10:17 am ] |
Post subject: | Re: Canberra mini mechanic |
Wayne @ Mini Works Australia is not in Canberra, but he's at the bottom end of Sydney and knows his minis http://www.miniworksaustralia.com.au/ |
Author: | winabbey [ Mon Oct 21, 2019 10:45 am ] |
This is in the list of Mini Businesses and has a Mini van in their advert - http://www.melbamotors.com/ Here's the full list - viewtopic.php?f=41&t=83593 |
Author: | DavidE [ Mon Oct 21, 2019 4:12 pm ] |
benwantsamini wrote: Hi all, I have been building a mini from ground up for the last three years. I am now at the pointy end and need a mechanic/auto elec in/around Canberra who knows minis to take it over the line. Any help would be greatly appreciated. Do you want a mechanic or an auto elect? Or both? |
Author: | p7676 [ Mon Oct 21, 2019 9:45 pm ] |
Maybe you should buy a new wiring harness easy to fit A work shop manual will also help on mechanicals do what you can .I got great help from Gotto ,Bill ,Simon and all the other Masters , my Mini goes well , also fitted reco engine and gearbox. Allen |
Author: | benwantsamini [ Tue Oct 22, 2019 6:06 am ] |
simon k wrote: Wayne @ Mini Works Australia is not in Canberra, but he's at the bottom end of Sydney and knows his minis http://www.miniworksaustralia.com.au/ Thanks Simon, I’ll keep that in mind. I just don’t have a tow vehicle and would have to borrow something from work which I’d rather avoid if possible. |
Author: | benwantsamini [ Tue Oct 22, 2019 6:07 am ] |
winabbey wrote: This is in the list of Mini Businesses and has a Mini van in their advert - http://www.melbamotors.com/ Here's the full list - viewtopic.php?f=41&t=83593 I forgot about Melba Motors, thanks Winabbey. |
Author: | benwantsamini [ Tue Oct 22, 2019 6:11 am ] |
DavidE wrote: benwantsamini wrote: Hi all, I have been building a mini from ground up for the last three years. I am now at the pointy end and need a mechanic/auto elec in/around Canberra who knows minis to take it over the line. Any help would be greatly appreciated. Do you want a mechanic or an auto elect? Or both? Technically both, I have bled the brakes with the Gunson easy-bleed but something still doesn’t seem right. Also the gear linkage is baffling me. Aside from that, it’s the wiring. |
Author: | benwantsamini [ Tue Oct 22, 2019 6:13 am ] |
p7676 wrote: Maybe you should buy a new wiring harness easy to fit A work shop manual will also help on mechanicals do what you can .I got great help from Gotto ,Bill ,Simon and all the other Masters , my Mini goes well , also fitted reco engine and gearbox. Allen My mini is a frankenmonster so I have a new harness but it won’t really match anything from the manual (which I also have). Electrics is also not my strength ![]() |
Author: | DavidE [ Tue Oct 22, 2019 6:50 am ] |
benwantsamini wrote: p7676 wrote: Maybe you should buy a new wiring harness easy to fit A work shop manual will also help on mechanicals do what you can .I got great help from Gotto ,Bill ,Simon and all the other Masters , my Mini goes well , also fitted reco engine and gearbox. Allen My mini is a frankenmonster so I have a new harness but it won’t really match anything from the manual (which I also have). Electrics is also not my strength ![]() Did you not get a wiring listing telling you which end of which wire connects to what? Is it an Australian built Mini or an import? Did you buy the harness from a local maker? Are you a member of the local club? Someone there may be willing to guide you. |
Author: | 9YaTaH [ Tue Oct 22, 2019 4:43 pm ] |
benwantsamini wrote: Hi all, I have been building a mini from ground up for the last three years. I am now at the pointy end and need a mechanic/auto elec in/around Canberra who knows minis to take it over the line. Any help would be greatly appreciated. I have personal experience and good reports for these two... https://www.autotechcanberra.com.au/ https://dynotune.com.au/ |
Author: | winabbey [ Tue Oct 22, 2019 7:28 pm ] |
9YaTaH wrote: benwantsamini wrote: Hi all, I have been building a mini from ground up for the last three years. I am now at the pointy end and need a mechanic/auto elec in/around Canberra who knows minis to take it over the line. Any help would be greatly appreciated. I have personal experience and good reports for these two... https://www.autotechcanberra.com.au/ https://dynotune.com.au/ If they are "Mini sympathetic" and know their way around Minis I'm happy to add them to the list of Mini Businesses, but need a clear endorsement. |
Author: | 9YaTaH [ Wed Oct 23, 2019 7:24 am ] |
winabbey wrote: If they are "Mini sympathetic" and know their way around Minis I'm happy to add them to the list of Mini Businesses, but need a clear endorsement. Doug, both these shops are not afraid of Mini's, but more importantly, are experts at multi-carb, fuel injection etc...just about any auto sparky could sort the loom problems Cheers, Mick |
Author: | 9YaTaH [ Wed Oct 23, 2019 3:54 pm ] |
benwantsamini wrote: I forgot about Melba Motors, thanks Winabbey. Ben, Mick Wilson from MM knows Mini's well and can probably recommend an auto leccy if your problems need a specialist...good luck, Mick |
Author: | benwantsamini [ Sat Oct 26, 2019 10:52 am ] |
Hi DavidE, I did but it isn’t a very detailed diagram. To be fare I haven’t tried yet and it might not be that difficult but energy and time are also lacking. The mini is Australian, harness is from mini sport in Adelaide and I do plan on joining a club once I get it registered. Are you a member? |
