Remote Shifter small rubber boot over pressed cup https://ausmini.com/forums/viewtopic.php?f=2&t=99418 |
Author: | MINI66 [ Sun Oct 20, 2019 8:07 am ] |
Post subject: | Remote Shifter small rubber boot over pressed cup |
Hi Guys I notice that the rubber small rubber boot that covers the cup that holds the stick in is not available. I have heard that you can use a pot joint boot. It is boot required? What are everyone else using? cheers Rick |
Author: | drmini in aust [ Sun Oct 20, 2019 10:16 am ] |
Post subject: | Re: Remote Shifter small rubber boot over pressed cup |
I haven't used one for 30 years....! |
Author: | winabbey [ Sun Oct 20, 2019 10:36 am ] |
It's a dust excluder - part GSV1073 in case you want to search for one. It seems the same part is used as a boot for pot joints. Mine was in good nick so I reused it when building the remote change extension. |
Author: | Morris 1100 [ Sun Oct 20, 2019 3:27 pm ] |
It is to stop water and dirt from getting into the shift, it's only important if you drive the car. |
Author: | MINI66 [ Sun Oct 20, 2019 6:14 pm ] |
Thanks guys. For $6.50 I might as well add one to the next parts order. cheers Rick |
