https://ausmini.com/forums/
Gear Box Help.
https://ausmini.com/forums/viewtopic.php?f=2&t=99377
Author:  2lateagain [ Sat Oct 05, 2019 12:12 pm ]
Post subject:  Gear Box Help.
Have a gear box, remote change D 22G68 with a serial number of B47304, the lay gear only appears to have a very light stamping of what appear to be small letters BW inside stamped box, nothing else is visible, is a 3 speed syncro. Any info on what the BW might be please, do not think it is anything special.
Graham
Author:  timmy201 [ Sat Oct 05, 2019 12:48 pm ]
Post subject:  Re: Gear Box Help.
Hi Graham, if you count all the teeth on the layshaft you can determine what it is
Author:  2lateagain [ Sat Oct 05, 2019 2:05 pm ]
Ok, thanks Tim, will do that.
Graham
Author:  Morris 1100 [ Sat Oct 05, 2019 5:31 pm ]
The BW on the gears and the B on the gearbox serial number refer to Borg Warner Australia gears. The original engine number would have finished with a B.
This would most likely be a Mini Deluxe box.
Not all cars got BW gears.
I was told by a prominent Mini parts guru that the BW gears were better quality than the English made gears.
Author:  timmy201 [ Sat Oct 05, 2019 5:48 pm ]
I talked to Graham earlier and it’s a Morris 1100 sandwich plate remote box with standard ratio laygear and 15/64 diff ratio (4.27)
