It is currently Sun Jul 06, 2025 7:18 pm
 Post subject: Smiths Tachometer Issues
PostPosted: Sun Apr 19, 2020 2:31 pm
Hi everyone,
I had a smiths tacho installed by the guy who services my ‘69 Mk2 Mini and it has never run accurately. After running the car for 5-10 minutes it will register 4000rpm at idle !!
Also the glass was broken during installation
Any advice on what I should look for to resolve the tacho issue and also thoughts on replacing the glass?
Also, the garage were great - not criticising them at all
PostPosted: Sun Apr 19, 2020 2:36 pm
Online
What make and model tacho?
PostPosted: Sun Apr 19, 2020 2:46 pm
It’s a Smith 8000RPM 80mm Tachometer part reference: RVC1006-00CB
PostPosted: Sun Apr 19, 2020 2:58 pm
Online
While awaiting comments from others perhaps have a look at this publication.
https://img1.wsimg.com/blobby/go/1975f8 ... 6555388667
PostPosted: Sun Apr 19, 2020 5:20 pm
RVC should mean suitable for electronic ignition...take a section of the glass to a glassworks and get them to cut you a new one (including drilling the hole in the centre) or contact an instrument shop near you (check out the Mini Businesses thread...)
PostPosted: Mon Apr 20, 2020 12:12 pm
There are conversion and or replacement circuits for these Smiths tachos in the UK for DYI use:
https://www.spiyda.com/tachometer-electronics.html
Otherwise you will need an instrument repairer, who might have access to a replacement crystal. Most Smiths tachos have a plastic "glass" with the red pointer riveted onto it.
Removing the bezel without damage is a patience tester!
Users browsing this forum: winabbey and 80 guests
