Gear changes become difficult as the engine heats up https://ausmini.com/forums/viewtopic.php?f=2&t=99368 |
Author: | MPP67 [ Mon Sep 30, 2019 10:26 am ] |
Post subject: | Gear changes become difficult as the engine heats up |
I have a rod change box that was reconditioned approximately 12 months ago. The gear changes in the car are fine until the car has been driven for 20 minutes or so. At this point the clutch has to be pushed closer to the floor and all gears are more difficult to select. I'm thinking it is a fluid issue of some sort but seeking guidance from the brains trust as to how to solve the issue. |
Author: | drmini in aust [ Mon Sep 30, 2019 1:30 pm ] |
Post subject: | Re: Gear changes become difficult as the engine heats up |
A mate had this problem once, it turned out to be not enough endfloat on the idler gear. Clearance there reduces as the box heats up. He had under .002" clearance, was not quite enough. Minimum is .0035" (3-1/2 thou) I think without looking it up. |
Author: | MPP67 [ Mon Sep 30, 2019 2:52 pm ] |
Thanks Doc. If that is the cause then my mini specialist can look at it as he reconditioned the box. |
Author: | lomin [ Mon Sep 30, 2019 8:27 pm ] |
Hi, pretty unusual problem in a rod change. something bent or tight ! always difficult to find as its not hot when recoing, and then all sorts of gearshift get bolted or pinned up ! I have also seen the lower selector shaft bent, the one that goes inside the gearbox from the rod change sleeve. The easiest first try imho is to borrow a known gearlever/ rod change system and bolt it on... then you can identify internal or external...remember the sleeve has to be able to move a bit too cheers Lindsay Siebler |
Author: | sitnlo62 [ Mon Sep 30, 2019 10:30 pm ] |
I would start with the basic clutch adjustment first before getting too carried away. Firstly loosen the small 1/4 " clutch adjusting bolt lock nut and unscrew (anti clockwise) the 1/4" bolt 1 full turn and re tighten the lock nut. Secondly unlock the 2 large throw out plunger stop nuts and loosen them 3/4 to 1 full turn.then Re lock them together. Once you have done this, try it and see if the situation has improved. From your description, if it is simply a clutch adjustment problem this should correct it. Alternatively get someone who is familiar with mini clutch adjustment to check it for you. |
Author: | Stibbsy [ Tue Oct 01, 2019 11:00 am ] |
I agree with Sitnlo62 on clutch. Just another thought, what grade oil are you using. Penrith HPR30 20W60 high zinc will also assist with better gear shifting. |
Author: | MPP67 [ Tue Oct 01, 2019 4:37 pm ] |
Thanks guys. I'll have a play with the clutch adjustment on the weekend and go from there. |
Author: | Hanra [ Wed Oct 02, 2019 3:48 pm ] |
The Penrite Mini is meant to be the high zinc oil. |
Author: | MPP67 [ Mon Oct 07, 2019 9:31 am ] |
Quick update. Completed a clutch adjustment on the weekend but the clutch pedal still had way too much free play. Upon closer inspection, the clutch pedal clovis pin was nowhere to be found. I searched under the floor carpet and located one R-clip and one clovis pin. The R-clip had bent so would not stay in situ. One new R-clip, replaced the clovis pin and now have a clutch peddle with no free play. Always amazes me what an old car will throw at you. Mark |
Author: | Mick [ Mon Oct 07, 2019 11:41 am ] |
Hanra wrote: The Penrite Mini is meant to be the high zinc oil. Its variable. Penrite Mini isn't as high as standard Penrite oils surprisingly. I've always wondered what Penrite mini brings to the table for the extra cost. I don't believe its anything actually. http://www.penriteoil.com.au/assets/pis_pdfs/HPR%2030%2020W-60%20(Mineral).pdf Versus: http://www.penriteoil.com.au/assets/pis_pdfs/HPR%2030%2020W-60%20(Mineral).pdf |
Author: | timmy201 [ Mon Oct 07, 2019 12:00 pm ] |
MPP67 wrote: Quick update. Completed a clutch adjustment on the weekend but the clutch pedal still had way too much free play. Upon closer inspection, the clutch pedal clovis pin was nowhere to be found. I searched under the floor carpet and located one R-clip and one clovis pin. The R-clip had bent so would not stay in situ. One new R-clip, replaced the clovis pin and now have a clutch peddle with no free play. Always amazes me what an old car will throw at you. Mark Mine did the same thing! But mine was bad all the time, not just after the engine heated up |
Author: | FNQ [ Mon Oct 07, 2019 2:47 pm ] |
The Penrite HPR range is their high Detergent Range whereas the Classic range is low detergent-. Low detergent oils increase the effectiveness of film formation ( a good thing). Hi detergent oils tend to clean away the film as well as varnish etc -not so good on the film bit, but their formulation is generally much higher Zc and Boron to allow for this.( they can achieve higher service intervals with this model) so the 10 10ths Race oil Modern could have 2200 ppm zn/boron etc in a high detergent base, where the classic formula has maybe 1600ppm in a low detergent base- and both offer good protection levels. Edit THIS IS MY INTERPRETATION ONLY so please do your own research. PS Break in oils tend to be LOW detergent oils |
Author: | Mick [ Mon Oct 07, 2019 4:09 pm ] |
FNQ wrote: The Penrite HPR range is their high Detergent Range whereas the Classic range is low detergent-. Low detergent oils increase the effectiveness of film formation ( a good thing). Hi detergent oils tend to clean away the film as well as varnish etc -not so good on the film bit, but their formulation is generally much higher Zc and Boron to allow for this.( they can achieve higher service intervals with this model) so the 10 10ths Race oil Modern could have 2200 ppm zn/boron etc in a high detergent base, where the classic formula has maybe 1600ppm in a low detergent base- and both offer good protection levels. Edit THIS IS MY INTERPRETATION ONLY so please do your own research. PS Break in oils tend to be LOW detergent oils Thanks for taking the time to spell this out. I figured there was a trade-off with zinc levels somewhere, as each and every formulation of mineral viscosity have specifically different levels of each. |
Author: | goodie [ Mon Oct 28, 2019 7:07 pm ] |
MPP67 wrote: Quick update. Completed a clutch adjustment on the weekend but the clutch pedal still had way too much free play. Upon closer inspection, the clutch pedal clovis pin was nowhere to be found. I searched under the floor carpet and located one R-clip and one clovis pin. The R-clip had bent so would not stay in situ. One new R-clip, replaced the clovis pin and now have a clutch peddle with no free play. Always amazes me what an old car will throw at you. Mark I would ditch the R clips (Especially if you have them on the brake pedal ) and re-fit split pins, simply because the current type of R clips are nowhere as good as the old type that you used to be able to buy , IE: they are a different length and profile to the ones that will suit , plus the metal doesn't have anywhere near the spring tension of the old type . How do I know this , because I changed both my Clevis pins out some years ago and instead of using split pins , (simply because they were harder to fit ) I thought i'd use R clips only because they were easier and quicker to install (WRONG ) , twice now I have found the R clip has dislodged from the brake pedal ![]() so that was enough for me to revert back to split pins . |
Author: | Mick [ Mon Oct 28, 2019 7:27 pm ] |
I've had this. When the R-Clip points down, the pedal when released will push the R-Clip down against the car body, pushing them out. I changed back to split pins and was a little easier going in how I bent them over so I could geth them out agin without too much stress. |
