Inlet & Exhaust Valves & Con Rods https://ausmini.com/forums/viewtopic.php?f=2&t=99349 |
Author: | cooperess [ Wed Sep 25, 2019 1:47 pm ] |
Post subject: | Inlet & Exhaust Valves & Con Rods |
Just started Mk2 Cooper S rebuild. Pistons are marked 060. What capacity is the motor? Valves are marked RIC127 & REC120. What are the details on these? Conrods AEG145. What do these come from? |
Author: | timmy201 [ Wed Sep 25, 2019 3:18 pm ] |
Post subject: | Re: Inlet & Exhaust Valves & Con Rods |
REC120 - 35.6mm inlet REC127 - 31.0mm exhaust Paul Ivey (Race Engine Components) uses these numbers, not sure if anyone else does http://www.gsvalves.co.uk/assets/race-e ... alogue.pdf |
Author: | TK [ Wed Sep 25, 2019 4:41 pm ] |
AEG145 is the bearing cap number. I think the rod will be 521. Later Cooper S 1275. Early were 177s |
Author: | drmini in aust [ Wed Sep 25, 2019 5:56 pm ] |
Pistons +.060" = 1330 cc. |
