Hi guys, I'm having a problem with my HIF44.
Here is a short video of an issue I solved a few weeks ago (thought I'd solved?). The nut needed tightening in order to make sure the butterfly spindle and the lever assembly were locked together.
https://youtu.be/ByQesdf6eK4I had a similar issue come back again, but here is the issue - I cannot tighten the nut to secure it. And also I can't back the nut off to remove it.
https://youtu.be/XmOYliguY3sI'm don't have a detailed knowledge of how it's assembled...is this likely to be a stripped thread? Or is there something that's vibrated loose and is missing? Here's some other pics...(I took off the spring myself)
Help appreciated
