Rover Japan 1989 engine bay wiring help needed - brown wires https://ausmini.com/forums/viewtopic.php?f=2&t=99320 |
Author: | 68AUTO [ Mon Sep 16, 2019 6:38 pm ] |
Post subject: | Rover Japan 1989 engine bay wiring help needed - brown wires |
Hi everyone, I need help. I have pulled the engine bay wiring apart because the previous owner was a HACK and the wiring was dangerous. I have everything else worked out except for 2 brown wires and 1 brown/red wire that are from the engine bay wiring loom. The car had a newer engine installed in it by the previous owner - which is a 1275cc from 1990 onwards. Any MPI/SPI is gone and it runs a carby now - also done by the previous owner. What I know about the wiring is: One of the Brown wires and the Brown/Red wire go to a Relay - that is located on the firewall close to the drivers side. The ends of these wires are at the front of the car - no connectors - they are cut. The other Brown wire (I believe) connects the starter solenoid to the Ignition. I have looked at many diagrams and manuals and I can't see anything similar. I have also looked at SPI to Carb pages for ideas. Jason. |
Author: | 68AUTO [ Mon Sep 16, 2019 7:13 pm ] |
Post subject: | Re: Rover Japan 1989 engine bay wiring help needed - brown w |
This is an image that I have found which looks close to what I want BUT it isn't in line with the relay wiring. Attachment: pre-engaged_starter_post-88.gif Currently the Brown and Brown/Red wires are connected to the relay. The diagram shows that: - the brown wire connects from the Starter to the Fuse box. - the Brown/Red wire connects from the Starter to the Relay - a Brown wire connects from the Relay to the Fuse box I could do this by removing the current Brown wire from the Relay and connect it to the Fuse box. But then... what fuse/link would I use? Jason |
Author: | 68AUTO [ Thu Sep 19, 2019 5:17 pm ] |
1 Brown wire goes from the Starter solenoid to Starter Relay The other Brown wire goes from the Starter solenoid to Ignition The Brown/Red wire goes from the Starter solenoid to Starter Relay Done. |
