It is currently Fri Jul 11, 2025 1:44 am
 Post subject: Water pump grease?
PostPosted: Sun Sep 15, 2019 3:44 pm
Hey guys. Installing the water pump right now and I see there is a port for water pump grease.
Should I do this? The old one doesn't seem to have any in there?
Can I use something I would have here is do I need to get "water pump grease" from auto shop?
Sent from my Pixel 2 XL using Tapatalk
 Post subject: Re: Water pump grease?
PostPosted: Sun Sep 15, 2019 4:57 pm
Looks like they have sealed bearings. Going without grease.
PostPosted: Sun Sep 15, 2019 6:05 pm
The hole is to let water out of the seal fails.
PostPosted: Sun Sep 15, 2019 6:43 pm
The workshop manual says it is for lubricating the bearings (perhaps in addition to allowing water out...)
PostPosted: Sun Sep 15, 2019 9:21 pm
That will be with respect to open cage bearings, but as you've noted you have sealed. Its now just outdated advice
Users browsing this forum: No registered users and 117 guests
