https://ausmini.com/forums/
Car pulls to the left
https://ausmini.com/forums/viewtopic.php?f=2&t=99221
Page 1 of 2
Author:  jambos [ Sun Sep 08, 2019 8:44 pm ]
Post subject:  Car pulls to the left
What could be the cause of the car pulling to the left when backing off accelerator at high speed?
Author:  gtogreen1969 [ Sun Sep 08, 2019 8:51 pm ]
Post subject:  Re: Car pulls to the left
As a start I woul be looking for loose steering or suspension parts. Check the steering rack for play, tie rod ends, steering arm bolts, all the suspension rubbers. Incorrect wheel alignment.
Author:  jambos [ Sun Sep 08, 2019 8:57 pm ]
Thanks, will check this out at the weekend.
Author:  9YaTaH [ Mon Sep 09, 2019 9:58 am ]
and suggest not driving it until the cause is found...even if it is only one tyre way lower than tuther...
Author:  Bill B [ Mon Sep 09, 2019 11:17 am ]
Has the car always done this, or is it only recent?
One of my minis has always done something similar - especially when going over a 'yump', where the front suspension first drops, then compresses when the weight of the car comes back down. The car used to steer to the right as it landed then to the left as the ride height changed.
Since the recent rebuild, it is not doing this. The only thing changed in the rebuild was fitting polyurethane bushes.
I am also thinking that getting the castor angles the same on both sides using adjustable lower control arms and tie bars might have some effect.
Author:  9YaTaH [ Mon Sep 09, 2019 8:40 pm ]
or the rear subframe alignment...
Author:  Bill B [ Mon Sep 09, 2019 11:34 pm ]
My problem or jumbos?
My car has been aligned on a laser all-wheel set up including rear wheel toe in.
Author:  9YaTaH [ Tue Sep 10, 2019 8:48 am ]
jumbos :arrow:
Author:  carter [ Thu Sep 12, 2019 12:27 pm ]
tie rod rubbers need replacing.
Author:  drmini in aust [ Thu Sep 12, 2019 1:52 pm ]
Steering arm loose on hub, can be worn arm, dowel or hub hole.
Been there fixed several.
[edit} Is more likely to occur with fat wheels.
Author:  jambos [ Thu Sep 12, 2019 8:20 pm ]
Thanks, will look at that this weekend
Author:  kiwiinwgtn [ Mon Oct 28, 2019 6:10 pm ]
Try swapping the tyres left to right. Worn tyres can make cars ver left or right. Most often at low speed though.
Sent from my SM-J530Y using Tapatalk
Author:  gtogreen1969 [ Mon Oct 28, 2019 6:11 pm ]
Its been a while now. How did you go with some of the suggestions?
Author:  9YaTaH [ Mon Oct 28, 2019 7:03 pm ]
Rears to the Front is a better idea :idea:
Author:  kiwiinwgtn [ Tue Nov 05, 2019 4:39 pm ]
If you swap left to right and it pulls the opposite way then you have found your problem.
