It is currently Wed Jul 09, 2025 9:41 pm
 Post subject: Removing Rust
PostPosted: Mon Sep 02, 2019 3:25 pm
Hi All,
Its been a while, I had my mini sitting in the shed for 10+ years and now Ive decided to get it going again (maybe needing some more advice soon) and give it a paint.
So upon removing the engine and using a wire brush on the grinder to remove the paint in the engine bay and surrounds I have come across some rust (as per pic below) in the sill below the headlights, would it be best to cut this out, make a new one and replace or is there a more simple way to consider?
The sill metal is very thin in places all the way across but the drivers side is the worst.
 Post subject: Re: Removing Rust
PostPosted: Mon Sep 02, 2019 8:24 pm
If you have the skill cut it out, make a new piece first. Make it look original .1mm steel
Allen
