It is currently Wed Jul 09, 2025 6:53 pm
PostPosted: Thu Aug 22, 2019 10:01 pm
Hi
I am refreshing my 1098cc engine (new rings and bearings)
Everything is still standard sizing (Bores, big-end bearings and main bearings)
Stock pistons for 1098cc motors normally 3 compression rings and 1 oil ring, mine has 2 compression rings and 1 oil ring. There are no markings on the pistons, and I'm a bit lost as to how to find the right rings for my pistons.
Any ideas?
PostPosted: Thu Aug 22, 2019 10:56 pm
The only thing I can find is a 998cc piston ring set for '89 onwards.
Appears the pistons have been changed at some point.
I'll measure the ring grooves and see if they are the same as the '89 onwards spec.
PostPosted: Fri Aug 23, 2019 9:59 pm
Hi, most times you find 3 ring pistons in 1098 they are Repco pistons, they were fitted from standard. They had wider rings (2mm or .078" top and 2nd?) and
the replacement rings are dearer then a set of new pistons, and the wider rings usually ruined the ring land and made it too wide ( if you can fit a .003" feeler gauge down the side of the ring then throw them away, they will fail in the next life quickly. 1100 motors also wear the bores badly most times, my opinion is get it measured, but the odds imho are 95% that it needs reboring.
The two ring numbers that come to mind are C1200 and M1259 they are the numbers for the 998 and 1098 repco pistons, just cannot remember which is which. 1100 motors do not take kindly to re ringing, with extremely high piston speeds
cheers Lindsay Siebler
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
Users browsing this forum: Bing [Bot], drmini in aust and 96 guests
