It is currently Wed Jul 09, 2025 6:55 pm
 Post subject: Oil cooler brackets - CS
PostPosted: Mon Aug 12, 2019 5:01 pm
Does anyone have a pic of how the cooper s oil cooler brackets bolt up? They seem to hang lower than the subframe (bolt on bottom of bracket is lower than the subframe?)
Rick
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Mon Aug 12, 2019 5:48 pm
Rick
If you are talking about the 13 Row horizontal oil cooler then the brackets are screwed to the lip of the front apron.
PostPosted: Tue Aug 13, 2019 9:57 am
Sweet. Thanks mate.
I was told they bolted to the sub frame, that is where the confusion started.
Rick
Ford DF LTD - 5Ltr
PostPosted: Tue Aug 13, 2019 11:27 am
Online
Pretty sure it's the GT ones that bolt to subframe.
PostPosted: Tue Aug 13, 2019 1:16 pm
Gt had brackets spotwelded to front apron panel
PostPosted: Thu Aug 15, 2019 8:44 am
The minisport website says in the detail that they affix to the subframe. That was were the confusion started
Ford DF LTD - 5Ltr
Users browsing this forum: Bing [Bot], drmini in aust, rocky&bullwinkle and 98 guests
