https://ausmini.com/forums/
Coil spring hi lo's- spring loose
https://ausmini.com/forums/viewtopic.php?f=2&t=98948
Author:  riley2 [ Tue Aug 13, 2019 10:00 am ]
Post subject:  Coil spring hi lo's- spring loose
Hi everyone,
Does anyone else out there have issues with their coil spring setup with hi lo's? I've tried to lower the car back to original height however, the springs both front and rear are loose and not seated properly when jacked up. After doing some research I think I have narrowed it down to 1 of 2 things,
1. No bump stop bump stop/ rubber buffer under the front suspension arms allowing the suspension arm to drop all the way down and creating too much space between the spring and where it sits (not sure about the rear)
2. The standard shocks are too long also when jacked up to adjust extending out the whole way also creating too much space to have the springs seat correctly
Has anyone else come across this problem before? if so what was the solution to the problem?
Pic of the front right when jacked up...
Author:  simon k [ Wed Aug 14, 2019 1:20 pm ]
Post subject:  Re: Coil spring hi lo's- spring loose
I'd be fitting rebound pads and see what it looks like. There should be a rebound pad at the rear too which stops the radius arm from dropping down too far
Author:  riley2 [ Wed Aug 14, 2019 1:56 pm ]
I have returned all 4 corners back to the lowest setting I possibly can and the front is still 20mm higher than the rear. I've ordered the front rebound pads too try and get the front equal with the rear or a tiny bit lower. Where does the rebound pads go on the rear? I can only see a bump stop at the top
Author:  1071 S [ Wed Aug 14, 2019 6:07 pm ]
Must admit I've not ever seen a "rebound stop" at the rear. If you remove the shock absorber you better have a prop under the brake drum ... or it falls on the floor..... I reckon you could use a bit of old seat belt to make a strop ... a bit like the drive shaft safety straps that some of the dragsters use..
The springs I've seen have a very small travel range. So, when set lower then the standard mini height (which they seem to almost always be) the strut will come loose at max rebound. I assumed you would need a non standard (much thicker) rebound stop at the front ...
Cheers, Ian
Author:  TK [ Wed Aug 14, 2019 7:15 pm ]
Simon K can you post a pic of the rear rebound pad please
Author:  gtogreen1969 [ Wed Aug 14, 2019 7:39 pm ]
Used on Hydro https://minikingdomonline.com.au/product/21a1517/
Author:  lomin [ Wed Aug 14, 2019 9:11 pm ]
Hi, I have Japansese coil springs in my road cooper S, and they ride brilliantly. But, I had to make unique Hilows and top spring platform to get height to work. They do not come loose, and that rear limiter goes on the subframe behind the cast area where the knuckle jointt fits in the trailing arm.
I would be suspicious that you will need to modify front hilo system..
Cheers Lindsay
Author:  riley2 [ Fri Aug 16, 2019 10:43 am ]
I've managed to get some standard rebound buffers which has helped get the front a little lower to get the car level however to get the front lower more like standard I think I might need something bigger. I found some 'oversized' rebound rubbers from the US but these are about $30 each plus shipping from mini mania.... I think this is US dollars which is bloody expensive!
https://www.minimania.com/part/2A4267C/ ... -Bump-Stop
Author:  timmy201 [ Fri Aug 16, 2019 11:14 am ]
Depends what you mean about “standard” ride height! From the factory they were very high. Remember they were designed to take 4 people and their luggage and still have suspension travel. Roads in the 60’s were also a lot poorer than now. Ideally you’d want the front driveshafts close to horizontal and the rear a bit higher than that. Then you can have a decent amount of travel before you hit the bumpstops (especially if the springs have less travel or are softer than the rubber cones)
This is a stock 850 from the brochure : viewtopic.php?f=32&t=73894
Author:  riley2 [ Thu Sep 26, 2019 12:28 pm ]
I have installed standard rebound buffers to the front which sorted the front end out which is now sitting perfectly.
I've got some rear rebound buffers to install on in the rear subframe, does anyone know the easiest way to install these? I'm planning on removing the radius arms to install them but there doesn't look like there is much room between the subframe and rear of car to get a bolt and washer in there......
Thanks for your help.
Author:  simon k [ Fri Sep 27, 2019 9:38 pm ]
Use a short bolt inserted from the subframe side and hold the nut up between the body and subframe with an open end spanner....
