Oil cooler brackets - CS https://ausmini.com/forums/viewtopic.php?f=2&t=98944 |
Author: | MINI66 [ Mon Aug 12, 2019 5:01 pm ] |
Post subject: | Oil cooler brackets - CS |
Does anyone have a pic of how the cooper s oil cooler brackets bolt up? They seem to hang lower than the subframe (bolt on bottom of bracket is lower than the subframe?) cheers Rick |
Author: | gtogreen1969 [ Mon Aug 12, 2019 5:48 pm ] |
Post subject: | Re: Oil cooler brackets - CS |
MINI66 wrote: Does anyone have a pic of how the cooper s oil cooler brackets bolt up? They seem to hang lower than the subframe (bolt on bottom of bracket is lower than the subframe?) cheers Rick If you are talking about the 13 Row horizontal oil cooler then the brackets are screwed to the lip of the front apron. Attachment: oil cooler screws.jpg Attachment: Repro oil cooler bracket .jpg Attachment: Oil Cooler Bracket.jpg
Author: | MINI66 [ Tue Aug 13, 2019 9:57 am ] |
Sweet. Thanks mate. I was told they bolted to the sub frame, that is where the confusion started. cheers Rick |
Author: | drmini in aust [ Tue Aug 13, 2019 11:27 am ] |
Pretty sure it's the GT ones that bolt to subframe. |
Author: | Goldbrocade_62 [ Tue Aug 13, 2019 1:16 pm ] |
drmini in aust wrote: Pretty sure it's the GT ones that bolt to subframe. Gt had brackets spotwelded to front apron panel |
Author: | MINI66 [ Thu Aug 15, 2019 8:44 am ] |
The minisport website says in the detail that they affix to the subframe. That was were the confusion started |
