Driving light mountings/ideas https://ausmini.com/forums/viewtopic.php?f=2&t=98938 |
Author: | MINIRO [ Sun Aug 11, 2019 8:06 am ] |
Post subject: | Driving light mountings/ideas |
Hi all, I have been on the hunt for driving light mounting bracket, but it seems that I have NFI what im actually looking for.. I have had the image below saved to my phone for years as a bit of inspiration for my own car & I really like how the middle 2 lights sits slightly higher than the outer 2. If know the name or style of this bracket my google search history would appreciate having a rest. Also if you have driving lights mounted on your roundnose I'd love to see pics! Thank you |
Author: | timmy201 [ Sun Aug 11, 2019 8:59 am ] |
Post subject: | Re: Driving light mountings/ideas |
I think that’s the “works type” spotlight bracket http://www.minispares.com/product/Class ... A1101.aspx I’ve got some a spot/fog pair of lamps that mount directly to the grille ![]() ![]() |
Author: | MINIRO [ Sun Aug 11, 2019 9:24 am ] |
timmy201 wrote: I think that’s the “works type” spotlight bracket Thanks mate, yeh I have seen those ones on mini spares but they apparently don't fit with the overriders, so guessing it not those ones on this car..http://www.minispares.com/product/Class ... A1101.aspx I’ve got some a spot/fog pair of lamps that mount directly to the grille ![]() ![]() Sent from my SM-G960F using Tapatalk |
Author: | fuzzy-hair-man [ Sun Aug 11, 2019 11:06 am ] |
Here's the light bar I made, it used thick plate bolted to the subframe and comes up through the grill, the centre support you can see that goes around the bumper adds a lot to the stability. I didn't like how most of the similar light bars available needed holes drilled in the front. ![]() |
Author: | timmy201 [ Sun Aug 11, 2019 11:56 am ] |
There’s a photo of one here, it doesn’t look much more than two foglight brackets with a bent piece of bar in the middle? http://www.theminiforum.co.uk/forums/to ... rk/page-20 |
Author: | Bill B [ Sun Aug 11, 2019 12:18 pm ] |
I have made a 'factory style' bar and brackets similar to "fuzzy-hair-man": bolts to subframe, under grill, no holes in stone tray. Have also made a modified version with just the brackets bolted to the subframe, under the grill and resting on the bumper bar. Again, no holes in the bodywork. |
Author: | winabbey [ Sun Aug 11, 2019 12:56 pm ] |
NSW Police mounted most driving lights directly on the panel behind the bumper. To improve rigidity and hence lessen vibration a large washer welded to some threaded tube was installed in each hole, with the Hella driving light stem in the middle. Attachment: Driving Light Mount.jpg Attachment: Driving Light Holes 40cm apart.jpg
Author: | Mister White Keys [ Sun Aug 11, 2019 1:55 pm ] |
Here's the setup I run on my roundie van. I picked up the vertical brackets from a mate years ago so no idea who made them originally but they mount off the bottom valance and the bonnet slam panel. I then made up a cross bar for the centre two lights. Everything is mounted nice and solidly and having the driving lights up slightly higher gives a good bit of range and spread at night. |
