It is currently Thu Jun 26, 2025 5:04 pm
 Post subject: Idler gear washers
PostPosted: Wed Aug 07, 2019 1:53 pm
Can anyone shed light on why the face has circular oil lines as opposed to straight cuts?
Are they better in dispersing oil?
Looking to make some oversized ones up and would love to know .
Simonw
Brisbane QLD
- 1969 Mini K
 Post subject: Re: Idler gear washers
PostPosted: Wed Aug 07, 2019 5:48 pm
It spreads the oil over the surface better.
Instead of spending $$$ on making thicker washers, why not deck the flange face a little.
Works for me.
I have a whole heap of 0.132" and 0.133" washers here, PM me if you want a few, cheap. 3/4" bore.
Suit A series, not A+.
PostPosted: Wed Aug 07, 2019 6:07 pm
The other option is to use a thinner gasket (cut from sheet gasket material)- Mine are about 19 thou from memory to make up for a worn thrust face on the gearbox.
Works for me.
PostPosted: Wed Aug 07, 2019 9:20 pm
Minisport sells a blue gasket which is 27 thou thick.
A standard red/pink one is about 32 thou.
PostPosted: Fri Aug 09, 2019 8:19 am
Thanks for the offer Kevin ,
The problem is that I have taken 20thou off the cover housing to clean up a melt down .
So I will need to compensate in the washer for that amount
I haven’t measured it yet but given the existing washers were 131-134 I would imagine I’m up for about 150+thou on one side .
Was just wondering whether straight grooves would disperse oil the same way as they are easier to grind in
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Aug 09, 2019 8:21 am
Thanks indigo
Thinner gasket will also help i think
Unfortunately this is for an auto so I will check the shape . May well be different
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Aug 09, 2019 1:20 pm
A concentric groove will result in an unworn ring on the housing.
Having the grooves eccentric is important. Easy to do with a 4 jaw lathe chuck, if you cannot get this done post them to me. I will do for postage.
Must be before hardening though.
