https://ausmini.com/forums/
Primary Gear rebore
https://ausmini.com/forums/viewtopic.php?f=2&t=98883
Author:  Chevrons [ Sun Jul 28, 2019 8:45 am ]
Post subject:  Primary Gear rebore
Looking for someone to line bore bushes in a primary gear on 1275 motor - pre A Plus series. Fitted with new bushes and requires machining to suit crankshaft. Prefer Geelong but will post to Melbs. Thanks in advance.
Author:  lomin [ Sun Jul 28, 2019 7:16 pm ]
Post subject:  Re: Primary Gear rebore
Hi, don't forget to measure the crankshaft diameters with a micrometer. The larger diameter is nearly always undersize, and if you machine it to standard size you will already be too large in the bush. Cheers Lindsay. I do have the name of a good machinist, who has done many for me if you are stuck, but you would have to post to Melbourne.
Author:  Chevrons [ Mon Jul 29, 2019 2:39 pm ]
Thanks Lindsey, we are aware of the undersize issue. Would appreciate the name and contact details of the machinist in Melbourne. Regards Chris
