https://ausmini.com/forums/
Battery master switch
https://ausmini.com/forums/viewtopic.php?f=2&t=98792
Author:  ricksmini [ Mon Jul 15, 2019 7:11 pm ]
Post subject:  Battery master switch
Hi all what sort of switch do people like to use as a master switch? I’m looking at either using a Narva 61043BL or an anbi switch. Open to suggestions. I would like to mount in the boot area close to the negative terminal
Author:  timmy201 [ Mon Jul 15, 2019 7:21 pm ]
Post subject:  Re: Battery master switch
I use a Narva 61082BL
Author:  fuzzy-hair-man [ Mon Jul 15, 2019 7:27 pm ]
I've just put in a 150A circuit breaker on the positive side I was worried that there's a long cable vulnerable under the car that is unfused.
I mounted the circuit breaker on the back of the rear seat, it has a manual breaker that would isolate the battery if needed or to slow down a possible theft...
It also lets me insulate the battery terminals better so things in the boot are less able to short the battery.
Author:  ricksmini [ Mon Jul 15, 2019 7:35 pm ]
Timmy201 did you wire that into the negative terminal? Does the red knob/ key come out?
Author:  timmy201 [ Mon Jul 15, 2019 7:40 pm ]
It’s a short negative battery lead to the switch and then short ground lead to the floor. No key, this is a switch only and not for anti theft - although the boot is locked
Author:  Bill B [ Tue Jul 16, 2019 10:19 pm ]
I have used a Hella isolation switch on the earth side.
It won't act as a fuse but is easily turned off in an emergency or as anti-theft.
Hella is a bit dearer than copies but seems a better quality item.
Needs a simple bracket to mount it.
