https://ausmini.com/forums/
Thickness of 7.5 inch Rotors
https://ausmini.com/forums/viewtopic.php?f=2&t=98791
Author:  slide [ Mon Jul 15, 2019 4:19 pm ]
Post subject:  Thickness of 7.5 inch Rotors
Does anyone know the minimum thickness at which 7.5 inch disc brake rotors can still be machined? Is it stamped on the rotor somewhere? I had some idea it was 10mm less than the new thickness which I seem to recall was around 6 mm. If I need new rotors which supplier is recommended?
Author:  slide [ Mon Jul 15, 2019 6:25 pm ]
Post subject:  Re: Thickness of 7.5 inch Rotors
Sorry that should read 1mm undersize, not 10mm.
Author:  drmini in aust [ Mon Jul 15, 2019 6:36 pm ]
They are 3/8" new, minimum used to be 5/16" = 8mm.
But so cheap new now they're not worth machining.
Author:  gtogreen1969 [ Mon Jul 15, 2019 6:51 pm ]
These were from MKO and have MIN THK 8 MM stamped onto them. https://minikingdomonline.com.au/produc ... lubman-gt/ Only $25
