1100 Big end bolts https://ausmini.com/forums/viewtopic.php?f=2&t=98773 |
Author: | bluehishouse [ Wed Jul 10, 2019 7:58 pm ] |
Post subject: | 1100 Big end bolts |
I'm struggling to find what big end bolts I need to get, standard conrods in an 1100. Ive searched a bit and found some broken links etc. What do i need? And do i run no lock tabs on them and the mains? Cheers! Sent from my SM-G950F using Tapatalk |
Author: | timmy201 [ Wed Jul 10, 2019 9:12 pm ] |
Post subject: | Re: 1100 Big end bolts |
I bought some ARP 200-6207 bolts - $125 for a set delivered, which is cheaper than buying standard bolts. |
Author: | drmini in aust [ Thu Jul 11, 2019 6:18 am ] |
No lock tabs on either, use ARP lube on the ARP rod bolts and oil on the standard mains. Check the main bolts are not too long- screw in without the caps, measure height to head. Should be a couple of mm less than cap height. |
