It is currently Thu Jul 10, 2025 2:34 pm
 Post subject: 1100 Big end bolts
PostPosted: Wed Jul 10, 2019 7:58 pm
I'm struggling to find what big end bolts I need to get, standard conrods in an 1100. Ive searched a bit and found some broken links etc. What do i need? And do i run no lock tabs on them and the mains?
Cheers!
Sent from my SM-G950F using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
 Post subject: Re: 1100 Big end bolts
PostPosted: Wed Jul 10, 2019 9:12 pm
I bought some ARP 200-6207 bolts - $125 for a set delivered, which is cheaper than buying standard bolts.
PostPosted: Thu Jul 11, 2019 6:18 am
No lock tabs on either, use ARP lube on the ARP rod bolts and oil on the standard mains.
Check the main bolts are not too long- screw in without the caps, measure height to head. Should be a couple of mm less than cap height.
Users browsing this forum: Bing [Bot] and 68 guests
