It is currently Fri Jul 11, 2025 3:23 am
 Post subject: 1967 Deluxe Rear Lights
PostPosted: Wed Jul 10, 2019 2:59 pm
I am searching for confirmation as to whether a 67 Deluxe came standard with two screw rear light assembly or three screw. In my case, the PO has installed one of each.
PostPosted: Wed Jul 10, 2019 3:02 pm
Pretty sure a 67 is 3 screw.
My 70 Mini is 2 screw, Oz made lights.
PostPosted: Wed Jul 10, 2019 3:34 pm
In his book John Snedddon says June 1967 for the change to two screw, although Lucas made the announcement in Jan 1967, so who knows for sure?
PostPosted: Wed Jul 10, 2019 3:44 pm
If it helps - the tail lights on YMA2S2 22269 are 3 screw and I think it was unrestored.
The original wiring loom would also indicate which type.
The early 3 screw assemblies had short wires coming out of the bulb sockets with lucas bullet connectors on the loom.
The later 2 screw assemblies had female spade plugs directly onto the back of the bulb sockets.
PostPosted: Thu Jul 11, 2019 9:13 am
Thanks brains trust.
PostPosted: Fri Jul 12, 2019 6:13 pm
My March April 67 built deluxe has 2 screw taillights
Simonw
Brisbane QLD
- 1969 Mini K
