Nissan Pulsar distributor https://ausmini.com/forums/viewtopic.php?f=2&t=98765 |
Author: | winston5454 [ Tue Jul 09, 2019 12:55 pm ] |
Post subject: | Nissan Pulsar distributor |
Hi, wondering if the N12 Nissan Pulsar distributor will fit in an early A series motor ( eg 1968 ) or will it only fit in an A plus engine ? regards, Winston. |
Author: | drmini in aust [ Tue Jul 09, 2019 6:47 pm ] |
Post subject: | Re: Nissan Pulsar distributor |
I have fitted them to both engines. The body's flange needs machining down circular to fit. An A series drive dog will fit on the shaft. Drill thru both to fit the Mini's 3/16" drive pin. An A+ drive dog will fit with the shaft bushed, the A+ drive pin is smaller diameter. And the A+ finger clamp works too. Seriously though, their advance curve isn't ideal for a Mini and the plate needs mods to limit advance to 9-10 deg at dizzy. Getting scarce too. It's easier these days to fit an electronic module to a Lucas 25D, 29D, 43D or 45D dizzy. |
